You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Greetings. I am requesting your help in finding the 5-digit door code for a 2007 Expedition. I have been told that for 2003 and newer trucks, the code is located under the passenger dash and on a black computer module with a Bosch label. I have had no luck and am under the suspicion that this code has moved since 2006.
From looking for mine for 3 months and reading from several boards, the 2007's do not have them anywhere on the vehicle. Like berry1234 said, you have to go to the dealer.
Thank you.
The dealer should have given you a card with the code.... Owners Guid says...
This code is located on the owner’s wallet card in the glove box and is
There are some excellent threads on the supercoupe forums about the control modules for the door buttons. The combinations are based on the placement, in sequence, of 5 resistors on the control module itself. If you can determine the location of that module (EVTM?) you can determine the button sequence. Remember, there are only 5 buttons, so each button has 2 possible numbers. Remove the cover of the module (drill rivets or whatever) and observe the placement of the resistors. Its slightly more complicated, but very doable.
If you are worried about the previous owner or dont know who it was, you can actually change the position of the resistors with a little soldering on the circuit board. Its brain surgery but not rocket science I will look-see in my material I have printed off some sites, maybe I can find more particulars. In a previous life (pre-retirement) I have modified hundreds, of circuit boards/components. These are really simple.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
