getting ready to change oil at 35000 in my truck 2006 stx with 5 speed manual tranny when should i change the tranny fluid and rear end fluid thanks for your comments
Unless you have submerged the rear end in water,you're good until 100k miles or more.I'm not too familiar with the Ford 5 speed,which uses MerconV fluid,but if it were mine I would have changed it at 30k miles.
So that mean we are good for 100K on the Front Diff as well? What about the T-Case?
I just changed all my driveline fluids at 90k, both diffs and T-case. T-Case fluid was a little brown, but other than that, it is cheap insurance. Very easy to drain and fill, so I would do it when you do the axles.
True. If you've got the time, and the money for it, it's cheap insurance to throw them all together...
