Banks Tuner
well with a module ( under the hood plugs into the harness) all you'll gain is slite power increase and it will be VERY hard on your dpf. modules claim to be undetectible but if you plug the dpf with soot or if it cracks from the extra heat they will NOT warranty your dpf and it costs darn near 2000 dollars! now with a tuner (flash device) you can get larger power gains larger fuel millage gains and you can get one to remove the dpf (wich happens to be about a 30 horse plug in the exhaust)
More power is always good, but I'm mainly interested in gaining MPG's. I just can't bring myself to do the DPF delete yet. I'd love to get rid of it, but not at the expense of my powertrain warranty. I was under the impression that Banks usually has the best products without voiding warranties... and do it CLEANLY. Do you think that that's a fair statement? You're certainly right in that I don't want to replace that damned DPF! I want it to work as designed until I'm ready to tear it out ( after warranty period ). I'm still trying to stay open minded to other good ideas though. Thanks for your input. I hope I get a few more opinions on this as well. As an aside, I spoke with my dealership yesterday and they have no heartache with mods. in general. Just not too drastic...
well i wouldnt assume banks is the best with the least hassle. if you want a good product that you wont have to remove the dpf then buy the spartan phalanx without the dpf delete tunes. then when you decide to upgrade your already 3/4 of the way there. or you could go with the sct livewire and later down the road it will have dpf delete capabilities as well. without removeing the dpf you'll be lucky to get 1-2 mpg gains compaired to 20+mpg with the dpf delete. if you decide to go that route and something happens you can always flash the truck back to stock and put the dpf back in place. hope i pointed you in a good direction.
banks is absolutely the best... the sct programmers look like a kid designed them. i talked 2 a guy at banks the other day... they r looking at having the six gun 4 the 6.4 by the end of the summer... i cant wait. u have 2 respect a company that takes time in2 making the programmer 2 make sure its right.... just my opinion though
Actually the intake is garanteed not to throw any codes. A lot of time was spent to verify the improvemt in air flow but also that it would not impact the engine or emmission system.
This will allow you to run the truck and regen fewer times over the same driving distance and both will run just fine with the DPF in place. The Six Gun will produce 118hp/235lb-ft over stock at the wheels and the ottomind will produce around 80hp/175lb-ft. I'll post up more info as they get released from our engineering dept.
So far the only MPG improvments we have seen are from our intake and exhaust systems ( I know, duh). Most of our customers are reporting around 1.5-2.2mpg better using both but this is by no means a garantee that's what you'll see as to many factors will affect your overall gain. The tuner (the ottomind) will be good for a minimum 10% better then stock however. I'll keep you all posted.
I assume the "ottomind" (strange name) keeps the DPF in place. If it is detectable by the dealer and anything goes wrong with the engine, can't they still blame that and deny warranty claims? I'd love to take that damned DPF off but don't want to until the warranty is over...
(BTW, I think I remember seeing Banks out at Bonneville at Speed Weeks way back in the mid and late 70's...)
