Need some new tires
Powerz69
Did you get the Michelin LTX AT2 tires? I am in the same boat 275/65/18, and what load rating did you get? I had LTX AT2's put on recently and noticed they are E load tires (10ply), I noticed the ride immediately, the truck handles like something entirely different now, stiff ride steering is different. Its frustrating because there's not a lot of choices out there for an 18 incher. I do tow a 16' trailer about 25-30 % of the time but the E load tires are killer, I am calling the shop tommorrow to see if this can be rectified.
I had a good conversation with a rep from Toyo a few years ago and he told me that the difference in C, D and E rated LT tires is all in the strength of the bead area, otherwise the tire structure is the same for the same tire series. By making the bead stronger the tire can handle more air pressure and more pressure equals greater load carrying capacity. Not really rocket science.
I'm on the hunt for some new tires. Factory tire size is 275/65/r18 very hard to find tires for r18. I did find some bfg 285/75 r18 that look very good. Would I be able to use a size like this without problems? Or should I stay with the factory size. I can get the michelin LTX/AT2 275/65/r18 or LTX/MS 285/65/r18 Also would these last tires eat up my gas? The brands I would like are bfg or michelin more toward michelin.
OK Tires is the best place to start for Toyos. I am sure there are a number of them in Edmonchuk.
Thanks for the heads up Big Dave
What you have said is what I have heard from shop techs, I am just a little precarious of running an E load tire at 40-45 psi, would this be an under inflated tire? If that were the case inner side wall heating and increased wear would happen. I thought that C, D, and E load tires have increased mass on the side walls? I know the Michelin LTX AT2 in a pmetric is almost 10 lbs lighter than the same tire with an E load rating. So the extra 10 lbs of rubber is in the bead? Also does anyone know what the safe PSI rating on an OEM 18 inch rim is?
Actually what the Toyo rep also told me is that after I chose a tire, his or another brand, I could contact him with a vehicle weight and he would give me a recommended air pressure. In other words it is the weight of the vehicle that determines correct tire operating pressure, not the construction of the tire. The construction of the tire only determines the MAXIMUM allowable operating pressure (ie. 35 psi for p-metric, 50 psi for Load Range C, 65 psi for LRD and 80 psi for LRE).
The thing to remember is that those so called "ply ratings" are a throwback to the bias ply days when tires actually had 6 or 8 or 10 separate plies. Todays radials typically have 2 or 3 ply sidewalls with an additional 2 or 3 plies in the tread area.
I once had a cheap set of Load Range E tires with 2 ply side walls and 5 plies in the tread area on an old F250. Travelling down a gravel road one day at about 70 km/h I had a flat on a rear wheel. When I took it to get fixed the the guy put 4 plugs in a row into the leak and it was still leaking. When he pulled the tire off the rim there was a rock about the size of my thumb inside the tire that had punched a hole straight through the center of the tread. The rock was not round, but neither did it have any particularly sharp edges. So much for those "tough 10 ply tires" the salesmen will try to talk you into.
Big Dave,
Just to confirm, you run E load tires at 40 -45 psi on an F-150? How many miles do you have on them. I went for a ride at 43-44 last night and it rides pretty much like stock, if I take it down to 37-38 I imagine they'd ride even better than the stock rugged trail TAs, which ran pretty good but I don't trust them on the ice and snow although i haven't used them on either yet as I bought my truck this past spring. Either way I like the Michelins in the ice and snow. So when towing I think I'd take them up to 50-55 psi. Although I would never exceed the recommended GVWR I doubt I would ever need to take them past 55 psi.
Have you ever heard of super springs? I am putting some on my truck as well. I hate how the *** end sags even with an empty 16' trailer, or even when I have gear in the box that I know is no where near capacity, even 400 lbs will get her starting to sag. I have done some research on the SS and people who use them are more than satisfied with their benefits. I am towing a loaded 7x16 trailer approx 1600 km north of Edmonton in December. It'll be a good test, I'll let you know how she goes with the E loads and Super springs.
i can shoot you a pic of how it looks if you like, send me a email.
to me the tires now fit the truck, the others alway looked too smal and i hated the nose down aditude it had stock.
BFG Deal from Ford
Just got 4 new BFG Rugged Trail 275/65 r 18 from my Ford dealer, they matched the lowest price I could find on line ($175/tire). Mounting and balancing was an extra $70. Ford has a promo right now - you get a $50 gas card if you buy 4 Michelin or BFG tires. Think it ends this month (Nov).
JP
JP
I never did end up getting tires. Got the tires shipped to the tire shop and canceled. I was going with the LT,AT2, 285/65/18. I noticed the tread was about 1/4 less then my factory wranglers new spare. Everyone that saw my tires laughed and said I have another year out of them. I will worry about tires next year. I think I will go with the P,AT2 or keep the factory wranglers. I know nothing about tires, well very little. I did look at the wranglers last number and they are a 113. The LT,AT2 are 124 Thats a big difference. The P,AT2 are 114 as mentioned. Like I said I'll worry about it next year and bring this thread back up. Sorry your not happy with them, tires for these rims are a small tough choice.
Teager
12-01-2013 02:40 PM
