ZF install complete, pictures
#46
i agree the newer vehicles in general all look the same, and are rather expensive to change at all. where as these trucks are pretty easy to work on and rather cheap. my wife-2-b has a 3000gt that needs a new transmission because she blew it racing... thats gonna cost us 2-3 grand that we just dont have. if i blew mine i would need what 500$? could do most of the labor myself... i absloutely LOVE my ford...
#47
#48
#49
hijackedLOL, OK Dirtballer, Your trans cross member should unbolt, and should consist of three pieces, on some of the newer trucks the top parts of the cross member may be riveted to the top of the frame on the inside of the "C" frame, and you may need to drill them out. Hope this helps.[/quote]
The problem is that crossmember sits on the inside frame rails i cant get it out sideways because it sits flush with the frame rails on the inside.
[IMG]<a href="http://s302.photobucket.com/albums/nn102/Burritts/Misc%20Pics/?action=view¤t=IMG_1163.jpg" target="_blank"><img src="http://i302.photobucket.com/albums/nn102/Burritts/Misc%20Pics/IMG_1163.jpg" border="0" alt="Photobucket"></a>[/IMG]
#50
Wide ratio for crawling... close ratio for economy?
Which would be better suited for a mostly street driven lifted bronco with 35's and 4:56 gears??
Somebody else asked this; how do you identify a wide ratio zf at the junkyard??
Also, are there s5-47 ZFs that bolt up to 351w or is that a BB/Diesel only trans??
#51
How to you get that crossmember out ? I am try to take mine out of 1981 ford f-100 and dont understand how it comes out.
#52
Damn, I forgot to mention. I found a 1988 6.9L Diesel truck on craigslist that had a 5 speed. The truck needed a few things(clutch, starter,etc). It was being sold for 500 bucks, probably could have talked him down. I think this is the way I will go to get my ZF.
Just to make sure, the 460 and the Diesel ZF bellhousings are the same correct?
#55
I'm pretty sure the AFR headed stroker 351 I have planned will be pushing that torque rating.
World Products 102041 - World Products 375 C.I.D. 455 HP Ford Man O'War Blocks - summitracing.com
The following users liked this post:
#56
#59
It depends on what engine you have. 300, 302, 351 have same bellhousing, 460 is by itself, as is the diesel.
EDIT: just noticed you said your putting in a 460, as long as the zf comes from a 460 it should work. Keep in mind you may need to move the trans crossmember, and the zf is hydraulic, vs mechanical in your truck.
#60
Ok, so I have been researching this swap for a few months now while I was looking for a tranny, and just want to make sure I have it all right before I tear into it. So, if some of you that have done this swap could check my info, and let me know if I am on the right track I would appreciate it.
My truck is an '86 F250HD Extra-Cab 4x4, with a 460, T-19, and hydraulic clutch. I have found a tranny from a '87 F350 4x4, 460, 5 speed. (for a $100 , yes it works, I have even driven the truck) I am getting the tranny, flywheel, clutch, and crossmember from the donor truck.
Crossmember: Have found some people reuse the old crossmember by drilling two new holes, some say you have to use the one that the 5 speed was mounted to.....is this just a truck by truck basis? Or is it just easier to use the one from the donor truck?
Slave Cylinder: Everything I have read says I can use the current slave cylinder from my truck, and that it will bolt to the ZF tranny, and have the proper stroke to operate the clutch correctly.
Transfer case: All the info I have found shows the mounting holes and input shaft diameter/splines were the same on the T-case/adapter for my truck up thru '97 for the F250/F350, so the new tranny should go with my current T-case with no issues. Also heard the T-case shifter should bolt to the new transmission and function with no issues.
Clutch/Flywheel: Little confused here. I have searched online, called a few autoparts stores, and talked to a local Ford dealer, and have been told by all the '86 T-19 I have and the '87 ZF I am swapping to use the same clutch. Part numbers are the same, shaft diameter and spline counts are the same, yet some of the guys doing the swap say you must use the ZF clutch as it is different splines. Many guys also say you need to swap flywheels, since the clutch for the ZF uses different mounting hole spacing on the flywheel.........but again, when calling around and searching the web, the flywheel for the '86 with the T-19 and the '87 with the ZF are the same part numbers, and same dimensions. So, any light you could shed on this would be appreciated.
Driveshafts: Have found most people have no issues with the front driveshaft after the swap, but the rear will most likely need to be shortened if not a standard cab truck. Since my Extra-Cab has the two piece rear driveline with the carrier bearing, most of the write ups I have seen say I will need to shorten the rear 2-3".
Sheetmetal: Looks like the 5 speed should fit the cab floor fine, but may need to work the area around the shifter with a few strategic taps with a BFH, as the ZF will sit a bit taller then the T-19 at the top of the tranny.
Am I missing anything, or have the wrong info with any of the above? Any tips or tricks not already posted in this thread you could share?
Thanks for any info, its greatly appreciated.
