British Columbia British Columbia
Join Chapter, Leader: sky Cowboy
Battery Draw
Old 05-22-2008, 01:01 PM
Dealership's Avatar
Dealership
Dealership is offline
Battery Draw
We've got a 1999 F350 Diesel, the batteries keep going dead after about 4 days. We have checked for a draw-no draw.We have replaced the batteries 4 times-the last time with Ford batteries, we have replaced the glow plug relay. Any ideas?
Old 05-22-2008, 10:54 PM
Zip's Avatar
Zip
Zip is offline
Are they going dead because of some sort of draw or do you mean dead as in dead. About all I can come up with right now is is the alt good, or some sort of draw like an interior light or something. My suggestion would be to do a search and see if you can come up with anything with that. Sorry I can't be of more help.
Old 05-23-2008, 09:43 AM
preppypyro's Avatar
preppypyro
preppypyro is offline
Sounds like there is a problem somewhere. From what i have always read, check the grounds first. Poor ground has been known to cause problems like this.
After you figure out if you have a bad ground or not, then it can get tricky.
What have you all done for testing so far?
Old 05-24-2008, 11:42 PM
rob188's Avatar
rob188
rob188 is offline
what it sounds like your alternators not charging the batts and your batteries only have enough charge in them to stop and start the truck for 4 days. if thats not the case then theres gotta be a draw, any aftermarket components?
Old 05-27-2008, 12:45 AM
Zip's Avatar
Zip
Zip is offline
Hey Dealership any headway on the problem.
JonJenn
01-29-2014 05:45 PM
dmilvae
03-01-2013 09:54 AM
firstgrasshopper
2004 - 2008 F150
02-12-2012 05:30 PM
86ford302
13
09-18-2009 07:30 PM
erbenson
1997-2006 Expedition & Navigator
07-24-2008 05:25 AM
Quick Reply: Battery Draw
