Rear Axles
Old 05-20-2008, 11:14 PM
schroel's Avatar
schroel
schroel is offline
Angry Rear Axles
Need your guys help. I have a 2006 FX4 with 26,000 miles and i'm hereing a noke in the rear axle when i turn left, right, when i come to a stop and when I pull into a drive way. What the hell is the problem.
Old 05-20-2008, 11:25 PM
powerz69's Avatar
powerz69
powerz69 is offline
Mine just started doing the same thing a few days ago. I did a search and came up with nothing. One post pointed towards CLUTCH PACKS? But no discription on what they were or how much $$ to fix.
Old 05-21-2008, 07:23 AM
schroel's Avatar
schroel
schroel is offline
Cool Rear Axle
I have been hereing this noise for a few weeks and it seem like it getting worst. But every time i take it back to the dealer thay can't find any thing.
I had a ticking noise in the motor and thay said thay did test and it pasted. I told the tech i still here the ticking. Ford enformed me that thier is nothing wrong with the motor. But I'm going to take it back in this week and get real answers. I'm a little Pissed off at this ford dealer.
Old 05-21-2008, 09:16 AM
Twinsdad98's Avatar
Twinsdad98
Twinsdad98 is offline
Schroel- your ticking is probably the cam phasers. Search the forum and you'll find several threads about it. Unless it's ticking like a diesel, the dealer probably isn't going to do anything. Yes, it can be annoying, but it doesn't effect the engine.
As to the axles, there was an issue with the clutch packs. It causes a shudder when you are accelerating and turning, like at an intersection. I was lucky enough to have mine changed under warranty. There is a tsb for this shudder issue. I'm not sure if your "noke" is the same issue or not.
Old 05-21-2008, 01:29 PM
04XLTRUNNER's Avatar
04XLTRUNNER
04XLTRUNNER is offline
i had the axle problem on my 04. i just went and had the fluid changed and it fixed the problem for about 15k miles. then it happened again.
Old 05-21-2008, 03:43 PM
powerz69's Avatar
powerz69
powerz69 is offline
Ha Ha, do a search on clutch packs (2 words not 1) you get lots of info. Sounds like lots are having the same problem with temp fixes after replacement.
