just bought 05 what needed to run 35's?
hello i just bought a 05 fx4 supercrew 5.4 how much of a lift will i need to run
Pro comps Extreme M/T the truck is bone stock for now
<table style="border-collapse: collapse; table-layout: fixed;" border="0" cellpadding="0" cellspacing="0" width="854"><col width="75"> <col width="104"> <col span="9" width="75"> <tbody><tr height="14"> <td class="xl28" height="14" width="75">PART</td> <td class="xl28" width="104">SIZES</td> <td class="xl28" width="75"> LOAD</td> <td class="xl28" width="75"> SIDEWALL</td> <td class="xl28" width="75">MAX.</td> <td class="xl28" width="75">OVERALL</td> <td class="xl28" width="75">OVERALL</td> <td class="xl28" width="75">TREAD</td> <td class="xl28" width="75">TREAD</td> <td class="xl28" width="75">RIM</td> <td class="xl28" width="75">WEIGHT</td> </tr> <tr height="14"> <td class="xl28" height="14">NUMBER</td> <td class="xl28"> </td> <td class="xl28"> RANGE</td> <td class="xl28"> </td> <td class="xl28">LOAD LBS.</td> <td class="xl28">DIAMETER (In.)</td> <td class="xl28">WIDTH (In.)</td> <td class="xl28">WIDTH (In.)</td> <td class="xl28">DEPTH</td> <td class="xl28">RANGE (In.)</td> <td class="xl28">LBS.</td> </tr> <tr height="14"> <td class="xl28" height="14"> </td> <td class="xl28"> </td> <td class="xl28"> </td> <td class="xl28"> </td> <td class="xl28">SINGLE/DUAL</td> <td class="xl28"> </td> <td class="xl28"> </td> <td class="xl28"> </td> <td class="xl28"> </td> <td class="xl28"> </td> <td class="xl28"> </td></tr></tbody></table>
<table style="border-collapse: collapse; table-layout: fixed;" border="0" cellpadding="0" cellspacing="0" width="854"><tbody><tr height="14"><td class="xl24" height="14">680305</td> <td class="xl24">LT305/70R18</td> <td class="xl24">E</td> <td class="xl24">OWL</td> <td class="xl26">3,750</td> <td class="xl24">35.1</td> <td class="xl24">12.2</td> <td class="xl24">10</td> <td class="xl24">21</td> <td class="xl24">8.0-10.0</td> <td class="xl24">71</td></tr></tbody></table>
yep, thats all there is to it. a 4" or 6" lift with 35" tires looks just fine. I personally prefer the look of the trucks with spacers alone. that, and the spacer is $70-80, and a lift kit is at least $1,500
the spacer pushes the lower control arm downward...this forces the outermost edge of the tire to edge "inward". if you don't get an alignment done, the outside edge of the tire will begin cupping and wear strangly.
I drove for at least 1,000 miles before getting an alignment. My tires were just starting to show the weird wear, so I finally got one done.
Originally Posted by rangerrod007
Why do you need an alignment when putting a leveling kit on? Isnt it just a spacer that sits on top of strut? t
This shouldnt change the geometry or alignment.
"Toe"
"Caster"
"Camber"
Caster, Camber, Toe
With an AS or similar installed, the relative position of the tread moves to negative degrees (compared to 0* horizontal factory settings). To compensate this, you would adjust the camber to bring it back to horizontal.
nope, the lift that is generated is because it "pushes" the coil-over downwards. that in turn pushes the lower control arm down and viola, truck sits higher
cowboyjesus
12-17-2013 05:35 PM
txgp17
15
04-26-2011 07:50 AM
