rubber o-rings and biodiesel ?
Old 05-14-2008, 01:02 PM
HAMOK's Avatar
HAMOK
HAMOK is offline
hey guys first time poster here, I have been researching biodiesel for awhile and just stumbled upon an 84 f250 6.9 w/ats turbo kit and a dual range od for 400.00 dollars. so now im serious about it. do i have to change all of the rubber components in the fuel system i.e. the ip , the lines , etc.. ? i have been slowly putting together all of the parts to do a prossesor in a trailer with a co2 fire system. any input on this would be greatly appreciated.
thanks in advanced
Troy
Old 05-14-2008, 07:28 PM
cookie88's Avatar
cookie88
cookie88 is offline
Hello Troy. Welcome to FTE!!!
An 84 model may very well still have some natural rubber components, but I don't know for sure. Diesel rated low pressure line (sae30r7) isn't all that expensive so it wouldn't be too big of an issue to replace the supply and return lines. Chances are a $400 6.9 probably needs the injection pump and injectors rebuilt anyways, so that really shouldn't be an issue either.
Sounds to me like all the pieces are falling into place for you.
Old 05-14-2008, 07:56 PM
HAMOK's Avatar
HAMOK
HAMOK is offline
thanks cookie88 , the truck has 126,000 mi on it , the 4-speed reverse pivot bolt "fell out" so i picked it up cheap, do you know of anyone who sells a rebuild kit with the right seals ?
thanks
Troy
Old 05-15-2008, 08:28 AM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
Hamok
Unfortunately the age of your truck will be a bit of a problem. Ford went to all vitron in about 1994 but prior to that there was a mix of vitron and rubber for several years.
First step would be talk to your local ford dealership parts store and see if they can tell you which parts are rubber then see if they have replacement vitron or similar substance parts. You can buy long tubes and hoses from other sources and probably some O-rings but gaskets and diaphragms will be part specific so will have to come from ford.
Old 05-15-2008, 11:41 AM
HAMOK's Avatar
HAMOK
HAMOK is offline
thanks phydeaux88 , i will start calling around , thanks for thew help guys.
Troy
Rose Clifford
15
05-11-2011 09:04 PM
derherr65
Bio-diesel, Propane & Alternative Diesel Engine Fuels
66
04-23-2007 08:23 AM
cpe41
16
12-01-2006 02:44 PM
Dieseldan7.3
16
09-12-2005 08:56 AM
Quick Reply: rubber o-rings and biodiesel ?
