Atc Switch Defective?
Old 05-08-2008, 06:58 PM
Big-Red-Lariat's Avatar
Big-Red-Lariat
Big-Red-Lariat is offline
just noticed that my auto temperature control switch has a 16 degree setting, then 19 degrees, but no 17 or 18. So is this thing broken or did FORD give us this as a free feature? What if 16 is too cold and 19 is too warm?
Old 05-08-2008, 11:28 PM
VFR_Man's Avatar
VFR_Man
VFR_Man is offline
Celsius, right? Mine, running the Fahrenheit scale, jumps from 60 to 65 and then again from 85 to 90 I believe. I guess they figure they covered the range of "normal" comfort and put the low and high settings in as a full cold and full hot setting.
Old 05-09-2008, 12:57 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
not broke, just wierd
my truck does the same as VFR_Man says
Old 05-09-2008, 07:03 AM
SDTruckMan's Avatar
SDTruckMan
SDTruckMan is offline
Mine does the same..
Old 05-10-2008, 12:57 PM
Big-Red-Lariat
Yes, it is Celsius...zero degrees is freezing, 100 boiling and everything else is in between.
Canada changed over in the 70's; makes more sense when you think about it, but was a pita to get used to after having learned Fahrenheit in school.
Old 05-10-2008, 01:17 PM
FatalErrorz's Avatar
FatalErrorz
FatalErrorz is offline
Fahrenheit is much more adjustable than celcius degrees. 25 celcius is 77f, and 27 celcius is 80.6f...That's 3.6 degrees/f in 2 degrees celcius. Our money system is metric...lol
