Well its not the CPS.!?
My Tack as been a bit erratic latly, it jump around some but most of the time it just hangs out 400-500 RPM over what my Aux. Idle control says i'm at and what I should be at with my gearing. so I replaced the CPS hoping it would fix the problem well no Joy.. any thoughts on what it could be? is this a bad sign/ thanks J
His problem is that the AIC is showing a different reading than the tack, and the tack is becoming erratic. Sorry cowboy I don't have a fix either for you...
-Robb
