fuel filter
fuel filter
I dont spend much time this forum, but I have a question. What is the trick to changing the fuel filter, 04 lariat 4x4. Also what is the right filter? I have a fram that has the old style locks but the OEM has a rubber tube with a disconnect with a disconnect on the filter! it also has a 90deg elbow on the output side.
thanks in advance for any help
hank
hank
fram g8018 i beleive is the correct filter, and you will need a disconnect tool to remove filter, yeah the filter comes with the old push in locks for uses on other applications, the one end on your truck should be a steel quick connect and the other have a blue clip that you have to slide the release out till it stops then insert the quick connect tool to release it same as steel end. I hope this helps
