this is my 3rd y-block site im asking help on... my y-block wont start! help PLEASE!
#61
i did get it you guys.... not sure if i like reading the " 'y'-cant this kid or his dad get this thing started" comments... but i guess its understandable... no need to pick on me that much, and thanks for everyones help and concerns about whether ive got it or not. i never gave up. now im about a month away from driving the 58 fairlane finally
#63
#65
best $35 i ever spent for my mustang and ranchero.
its full of my own notes as well from the years. stickies for quick reference pages and indexed to what i'm working on.
amazon/ebay is the way to go for availability.
then hit up the aftermarket books for Y parts. Concours, Carpenter etc.
if you got time and printer paper, check my previous post with 58 manual link.
high res for decent printouts, get a 3 hole punch and a binder. you're on your way.
but didnt this guy[i wanted to say kid... but since im 18 also cant really] end up taking it to a garage, and paying some one else to fix it?
#66
well i know some of you probably have seen my other posts on the HAMB, or yblocksforever, but you guys also helped me out and well, i took it to a mechanic, and he got it for us
it was a combo of a lot of things, but all in all, 85 bucks later... and 330 bucks later for a new carb... i have this
(ill make new videos once i get a radiator on there and we get closer to drivable conditions)
YouTube - 1958 ford 292 yblock at idle! love the sound!
YouTube - 1958 ford 292 y-block IT RUNS!!!!
personally i think taking it to a mechanic is sort of giving up on it... just my personall experince... but then again... ive been around cars and trucks for 18 and a half years.... so ive got that drive to work on anything that drives... or could possibly drive... **shrugs**
#67
From the SECOND site he went to:
"...but i guess it was a mixture of a lot of things. timing was off, it was off by a few teeth, he had to move the distributor a little bit (we did that everytime we tried starting it), i need a new carb he said, and spoiled gas (i knew it was spoiled, i used a seperate gas canister with clean fresh gas to start it though)...."
His impatients is his biggest problem - d**n punk teenagers anyhow....
#68
hey man... im the same age as him... i dont give up on my truck... if i come over here, and ask for a sudjestion on the motor... i take it... and i use it well.... ive only not listend to 2 guys on here so far... and that was about a gas tank....[they looked the same in the pic.... but different sending units, and fuel pick up on the wrong side...
#70
#71
I've had the same problem. The firing order is correct but out of sinc. with TDC for the ignition stroke. It sounds to me you are firing at TDC for the exhaust stroke and therefore backfiring through the exhaust manifold. Solution: Set the flywheel to the TDC mark then rotate the distributor shaft 180 degrees (half a turn) before re-fitting the distributor. Use carburetor spray to temporally eliminate the other, fuel based, variables. If this works you know you have solved one problem and can move onto the fuel supply afterwards. Always try to work on one variable at a time. Hope this helps, AussieDrew.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
ivegotahammer
28
10-04-2022 02:08 AM
camerahunter
13
12-10-2014 01:16 PM
station45
09-06-2012 06:23 PM
ashalee
1983 - 2012 Ranger & B-Series
08-17-2011 11:11 PM
Greg Bockelman
11-15-2005 04:28 PM
