Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.0L V6
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-27-2008, 03:06 PM
devilman13xx devilman13xx is offline
devilman13xx is starting off with a positive reputation.
97 ranger wont start, has spark and fuel
my buddies truck died on him while going down the interstate. its a 97 ranger 3.0 auto.
we had it towed to my house thinking it may have been a frozen a/c comp.
anyways after realizing it wasnt that i checked the fuel pressure and got 40psi while cranking.
i hooked up an inline spark tester to the driverside middle plug and it lit up.
we tryed spraying some starting fluid into the intake and it shot out a huge flame after cranking for a bit.
im thinking it the timing chain but im not a ranger expert so i figured id ask some.
  #2 (permalink)
Old 04-28-2008, 08:29 AM
waynebo waynebo is offline
waynebo is starting off with a positive reputation.
I have a post below you,,Won't start,,same problem,no answer yet..i'm thinking maybe cam position sensor. but i read somewhere that it should still run off the crank position sensor so i don't know,,wayne
__________________
<---i'm miss'in the same tooth..
95 f250 P.S 2wd 5spd,,,,
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
