Jet size???? motor 272, carb Autolite 2100 292J C3TF-K
Hie everyone.
I have a bit of a problem with my truck carb. I have experienced som problem with "blowouts" both thru the exhaust and the carb. Not often by now and then. So I dissassambled the carb in the believe of that it got to much fuel. What I found was a set of 35 jets????? is this ok or not??. I believe that it would be somewhere arond 48, someone told me, anyone??.
If i screw in the air/fuel mixture screws to the bottom the engine still runs, defenetly not good but it runs.
I have also tried spraying "startgas" in swedish sorry, arround the intake and carb to look for vacume loses. But it was all good.
In what end would I start, New jets, renovation kit......... suggestions.
All info and help gladly appreciated.
C3TF-9510-K = C3TZ-9510-U (Auto-Lite/Motorcraft CA-271)
Original application: 1963/64 F100/700 292 2V
1964/72 Ford Truck Parts Catalog / Carburetor Parts List #14A
D4AZ-9A586-A .. Carb Kit (Motorcraft CT-499-D)
78-9533-B .. Jet #48 / 0-5,000 ft. (Motorcraft CJ-55)
C1AZ-9533-B .. Jet #46 / 5,000-10,000 ft. (Motorcraft CJ-20)
C1AZ-9533-F .. Jet #44 / 10,000-15,000 ft. (Motorcraft CJ-24)
Ford sold Auto-Lite circa 1971, then started Motorcraft, retaining the original Auto-Lite part numbers.
Thanks everyone.
I would be surprised if the powervalve is blown judging by the backfires I have been experience
Is it possible to see on the powervalve, if I dissassamble the carb, visually that it is Blown? I took a look at it here the other day but I could see any visual damages on it.
If I buy the carb kit that Numberdummy referes to does it include the part for the powervalve as well.
Best regards Jimmy
Best regards Jimmy
D4AZ9A586A .. Carb Kit (Motorcraft CT-499-D) **
Available from Ford
MSRP: $31.52 / ftepartsguy.com price: $18.91
This kit fits all Ford 2V carbs from 1962 thru 1974.
I listed the jets for your information, they are no longer available from Ford (they do not come in the kit)...I'll see if I can find them elsewhere.
** When typing part numbers into the website = REMOVE the hyphens, as I did above.
Straight from Holley's(I know you have a A.L.) web site.
If you have a carburetor older than 1992 (or you have experienced
an extreme backfire) and expect a blown power valve,
use this simple test. TEST: At idle turn your idle mixture screws
(found on the side of the metering block) all the way in. If your
engine dies the power valve is not blown.
