Wondering Why
I just tried going there and the top of your IE should be a yellowish bar to click on to download the activex controller but of coarse my windows vista is not wanting to cooperate w/ me and is blocking me out, go figure.
i login every now and then, but no one is ever on. MOF, i am in the MAIN channel right now.
FYI, it's not activeX it's JAVA based. you need to make sure you have java installed and working:
Download Free Java Software - Sun Microsystems
on
just like David said
Acceptable Discussion:
- No profanity
- No overtly off-topic discussion (keep it centered around Ford trucks)
- No abuse of other people
- No commericial advertising
All postings and IP addresses are logged to prevent abuse.
You must have a browser that supports Java and Java must be enabled in order to use our chat.
<!-- Konabody --><!-- google_ad_section_end --><!-- End Content -->******** language=Javascript1.1 src="http://ad.doubleclick.net/adj/fordtrucks.tmus/hp;sect=hp;kw=bottom;abr=!webtv;tile=1;sz=728x90;o rd=' + ord + '?">*********>
Works for me on my Apple Powerbook. You should momentarily see a "coffee cup" logo flash and then it go into the chat screen. That's if you have the proper Java stuff running on your computer.....
I went back into it and successfully logged in by naming myself, it logged me in.
those of you guys having problems need to click the "do i have java" link at the site in my previous post. this will check and tell you what platform you are currently running.
the white x means either you don't have java or the version you are running is too old. ie and firefox both work well with the chat.
