There is a small fan running under the hood when the truck is off. Is this normal?
Hi, I have an 87 f150 just got it running still not to familiar with it yet. When I turn the truck off there is a small fan conected with a duct to the manifold. It runs when the truck is off, is this normal. I have disconected the negative battery cable so I dont kill the battery. Any help would be good. Thanks, Joe
Which engine do you have, the 4.9 liter six cylinder? My 1988 F-150 with that engine has this, my fan only comes on once in a while when I shut the engine off. Your fan should shut off by itself in a while.
The fan is designed to cool off the injectors.I had the same truck you own.My fan would only run in extremly hot weather,and then only for a few minutes after shut down.If yours is running continuosly,you could have a bad sensor or fan relay.
I also had a 1987 F150 with the six, it had that fan. The fan itself lasts a long time, but they are a little hard to get when needing replacement. That truck went just over 300,000 miles before I sold it. I only replaced the fan once.
I wonder if it was a campaign for engines that went into heat soak while still under warranty? (Chrysler calls it a campaign, Ford might call it something different) That would explain why not many engines have it.
