1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
diesel fuel in my coolant overflow!
Old 04-05-2008, 03:26 AM
montanasteve's Avatar
montanasteve
montanasteve is offline
well, i've got diesel fuel coming out of my overflow tank. first suggestions were a blown head gasket, but i had a friend suggest the injector cup in the head, as that's the only way that much fuel would make it into the coolant. oil looks clean on the dipstick, but could have water in it, would have to drain to find out. if it is the injector cup, what's involved with replacing it? also, other symptoms are excess white smoke at cold starts, and the engine runs cooler in the range than normal.
'02 f250 psd 6spd
thanks,
steve
Old 04-05-2008, 03:39 AM
RogueSpear2023's Avatar
RogueSpear2023
RogueSpear2023 is offline
How many miles are on the truck? Head gaskets are extremely rare in the trucks, but it could happen. On cold starts you should get some white smoke or has it changed recently. Also do could you list any modifications you have done to the truck?(i.e. tuners, intake, exhaust, etc.)
Old 04-05-2008, 08:41 AM
locked up's Avatar
locked up
locked up is offline
Maybe your EGR cooler..
Old 04-05-2008, 09:00 AM
F350-6's Avatar
F350-6
F350-6 is offline
Welcome to FTE Steve. Maybe try asking your question down in the 7.3 section. Here's a link 1999 - 2003 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
My guess is injector cups.
Old 04-05-2008, 09:12 AM
montanasteve
more info on the truck
2002 F250 7.3L PSD, bone stock, 119000 miles. Seems a bit early for a head gasket, eh? The truck has never overheated. First started noticing the "leak" a couple of weeks ago - diesel in the front of the passenger side of the engine compartment, wet all around the battery. Took a few looks to figure out it was coming out of the coolant reservoir when it was hot. Just figured that out yesterday. As far as the smoke goes at startup, it's more than what should be there, as I've had another 2002 PSD as a work truck in the past, and it didn't smoke like this one. Now, I just read in my Chilton's manual that the fuel heater (under the fuel filter) doesn't kick on without the truck in neutral and the parking brake depressed. My parking brake cable snapped a couple of months back, so I haven't been using it. Anyone know if that's true about the fuel heater not kicking on without having the parking brake engaged? That would explain the white smoke.
Old 04-05-2008, 09:27 AM
montanasteve
about the white smoke
Oops, I was referring to the manifold air heater that triggers after the glow plugs shut down and the parking brake is on, not the fuel heater as I stated earlier.
