Strange coolant leak '94 302
Old 10-25-2016, 02:38 PM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is offline
You can rent one of those pressure testers that connect to the radiator fill neck in place of the cap, and pump up the pressure in the cooling system. With coolant in the system, it should be easy to trace any leaks. Yours sounds like the water pump needs to be replaced.
Supercab
16
05-02-2020 05:30 PM
Ckn087
12-17-2017 08:34 PM
Mikedibenedetto
05-29-2017 10:31 PM
BeholdenZippy
11-17-2016 02:22 PM
Berardini2121
1978 - 1996 Big Bronco
05-11-2016 05:31 PM
Quick Reply: Strange coolant leak '94 302
