Body lifts, the why not and the how to
#31
Originally Posted by waynaferd
The reason I ask is my body lift was bought for an 84 F-150, than I used it again in an 87 Ramcharger, and now again in my 94 F-150, and had do get a Borgeson shaft for the R/C but never needed anything for the Fords.
So I didn't know if steering shafts needed any attention or not, since nothing was in the kit.
Thanks!!
Thanks!!
#33
Thanks!!
Thanks!!
#36
#38
Originally Posted by HighProCam
When I body lifted my truck, I thought it was weird that it didn't have some sort of steering extension. I called the manufacturer to double check, and they said the kit didn't require one. You can make up the difference by loosening the bolts below the dash that hold your steering column up and adjusting the column inward, poking more column out of your firewall, hence moving your wheel closer to the dash. Then lock the bolts back down to hold your column there. That's for a late 70s truck though.
#40
Originally Posted by FTE Fred
I will be honest - if that is the manufacturers advice, I would be running far away from them... and at a bare minimum would not be opperating the truck on the road.
#41
There's no such thing as "just a 3" body lift".
A one inch body lift is crap much less 3".
There are very few reasons They are acceptable and for a engine swap or something of that sort is about the only good reason, and it still must be done properly.
Takeing the bolt out of the steering for extra length is not proper.
#42
I'm not sure everyone is seeing what he's saying. There are 4 slotted holes in dash where the column is bolted in. They're there for adjustments, I don't see any problem with it. In fact I think the whole safety issue with body lifts is blown way out of proportion. That said, they still bring the **** and I'd never run one unless I absolutely had to.
#44
I didn’t remove any bolts ?
I’m curious if anyone else has a late 70s F250 with a body lift and if they have had a similar experience or not. I agree with safety and adjusting the column on its adjustment bracket didn’t sound to bad to me.
Originally Posted by STGFordCrazy04
For obvious reasons Im unsubscribing to this thread and many of the other recent threads.
This thread is ALSO how to body lift and who better than someone who has actually done one, talk on it. I can’t imagine why there is less than a dozen people that post in here. Like STGFordCrazy04 says, everybody says do this, don’t do that…. Yet nobody can talk from experience and they barely have reasons why. The difference between doing and reading about it. I can take a picture of my body lift blocks…
Another benefit is reduced drive line angles over going all springs.
More room for that high rise intake.
