Catalytic converter Cherry Red!!!!
when i worked at the garage we had a jeep grand cherokee come off the highway customer said it was losing power and couldnt get up to speed, ran ok at an idle but when u revved it it ran terrible, pulled it on the lift and all 3 cats were glowing red, 2000 bucks later and 3 new cats he was back on the road, after pulling the old ones off you couldnt see any light through them and u could see how clogged the honeycombs were
Higher octane rating does not make a fuel burn hotter, only takes more to "set it off".
See here,
Octane rating - Wikipedia, the free encyclopedia
Higher octane tends to be a better quality fuel at least where I live, I run premium in dirt bikes, chainsaws, lawnmowers, boats just anything that isn't used regularly.
Regular no lead has a lot more impurities in it so does mid grade, if left to sit in a fuel system like a carb's bowl it settles gumming up the works.
Premium doesn't do that, at least not while a motor over winters unused until spring again.
I use the cheapest fuel I can get for the trucks regardless of octane rating, it goes through it like crap through a goose so its not in it long enough to hurt anything. That and its doesn't sit months at a time unused either.
on
Sorry but I gotta disagree with ya on that one, Octane level has nothing to do with it.
See here,
See here,
Many high-performance engines are designed to operate with a high maximum compression, and thus demand high-octane premium gasoline. A common misconception is that power output or fuel mileage can be improved by burning higher octane fuel than a particular engine was designed for. The power output of an engine depends in part on the energy density of its fuel, but similar fuels with different octane ratings have similar density. Since switching to a higher octane fuel does not add any more hydrocarbon content or oxygen, the engine cannot produce more power.
I stated that running higher octane in an engine such as his (a low compression engine comparatively/ An engine specifically designed to run on 87 octane) Will run over rich when subjected to a habitual use of higher octane fuels (a result of residual incomplete ignition of the higher octane blend. 87 octane has the best "overall" easily combustive properties of all the normally used octanes. I never said anything about higher octanes running hotter in his application. In fact it would produce just the opposite, a quenching effect.
Which part do we disagree ?
Unless there is a misfire, the air/fuel ratio will not change between gasolines with different octane ratings. Higher octane fuel can tolerate more spark advance (with all else being equal) which can gain some torque, but as the wikipedia reference says, the fuel itself is not the source of the increase.
Who dug up this old thread anyway?
Well the part where common pump gas, using premium rather then regular would or could make any difference as it pertains to this thread.
More to my point as stated above, the air/fuel mixture is not changed with the use of higher of lower octane, no btu change in effect so to speak.
Don't know, been away couple few days and didn't realize it was.
on
ISSUE: Rough idle, hesitation, poor throttle response, induction backfire and stalls during cold start/warm up may be caused by the poor volatility of some high octane premium grade unleaded fuels (91 octane or higher (R+M)/2). When compared to regular grade unleaded fuel (87 octane (R+M)/2), high octane premium grade unleaded fuel may cause long crank time.
ACTION: Use a regular grade unleaded fuel in all vehicles, except where a premium unleaded fuel is recommended in the Owner Guide. If lean air-fuel type symptoms are experienced, determine the grade and brand of fuel used and offer the following service tips.
^ Advise those using a higher octane grade fuel to switch to a regular grade unleaded fuel. For those using a regular grade fuel, advise them to try another brand.
^ Do not advise using a higher octane unleaded fuel than is recommended for that specific engine. Ford engines are designed to perform best using a high quality regular grade unleaded fuel.
^ Only advise using a higher octane unleaded fuel to avoid potentially damaging spark knock or ping, but do so only after mechanical fixes are ineffective.
NOTE: ALL UNLEADED GASOLINES USED SHOULD CONTAIN DETERGENT ADDITIVES THAT ARE ADVERTISED AS HAVING "KEEP CLEAN" OR "CLEAN UP" PERFORMANCE FOR BOTH INTAKE VALVES AND FUEL INJECTORS.
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: INFORMATION ONLY
OASIS CODES: 404000
Induction backfire?
This would now semantically qualify for use of the word "Overrich"? (maybe not, I think that's actually two words)
The most common cause for clogged cats is a rich mixture. The two most common causes for a rich mixture are a vacuum leak or old oxygen sensors. Either cause should light the Check Engine light on a Ford before the cats clog with carbon or melt down.
If the car has gone more than 60,000 miles since it got new oxygen sensors, they should be changed. Before doing that, look for vacuum leaks anywhere in the intake system. There can be other causes for unburned fuel igniting in the cats, like leaky injectors, but they are often rare. Pulling the codes can help diagnose the cause.
If you replace the cats but don't repair the cause of them filling with soot, then you run the risk of clogging the new cats and perhaps melting the matrices too. Glowing cats are a symptom, so don't overlook the original disease in your desperation for a cure.
Scott
Scott
on
Scott
Scott
True, if you don't address the cause, you will repeat the effect.
Sooooo! He never mentioned what flavor of octane he actually used! So, I guess we won't know what this particular cause was! Phantom threads exhumed from the past can be a real pisser, especially when the lack of eventual outcome tends to mute the arguments that develop.
#30
Fullmetal460
03-31-2012 12:41 AM
1662_CrewDAWG
07-20-2003 09:09 PM
