Power Brake Vacuum
Power Brake Vacuum
I have been doing some searching, I am putting a power booster and dual master on my 52 with the original flathead. Will the flathead produce enough vacuum and if so where is the best place to connect, there is a vacuum port on my Offy duall intake. I have heard you can also get it from the fuel pump or install an electric vacuum pump. I think this is common conversion so the answer should be simple, I hope.
Thanks for all the great info
I don't know the answer of the question, I just saw you were from Peterborough. I remember when I was a kid we would drive up to Rice lake to go fishing and we would always visit the lift lock in Peterborough. Brought back some good memories.
I am sure someone will be along soon with some flathead help.
