What part is this ????
03-12-2008, 07:43 PM
Getting smoke while cranking?...
03-12-2008, 07:48 PM
03-12-2008, 07:56 PM
Quote:
Originally Posted by 250turbo
is truck idi?
kurt
Good call ,,, none of us have an external regulator
What year truck are we working on ?...
03-12-2008, 07:59 PM
on
No smoke its a 92 non turbo idi.
03-12-2008, 08:10 PM
on
well first ting is you are in the wrong forum... but if you touched a ground to that it should not have did anything seeing that it is attached to the inner fender...
these trucks are grounded throughout the whole truck...
try taking kill wire off injection pump
03-12-2008, 08:14 PM
on
It was running fine before i took out the batt tray. what part is this ?
03-12-2008, 08:15 PM
on
that is the starter relay.. aka. soleinoid... spell check???
03-12-2008, 08:22 PM
on
is it cranking and not firing up or is it not cranking at all???
03-12-2008, 08:24 PM
how cold is it there,do you need glow plug?
03-12-2008, 08:28 PM
03-12-2008, 08:36 PM
on
it is cranking normally . the WTS light is working but i dont hear the click when the light goes out . it was aroud 50 today but was sitting for night time fuse 17 under the hood or in the cab ?
03-12-2008, 08:40 PM
on
it would be under the hood..
03-12-2008, 08:42 PM
can't remember,idi was 12 yrs.ago, i think in cab.
03-12-2008, 08:47 PM
on
thanks i will in in the AM it dark here now . is there any way to test the relay and or voltage regulator ?
