Terrible "creaking" in front suspension
.....what could it be. When I turn the wheel or go over a small bump the creaking sound is very loud. It sounds like a sound from a new truck. It is in the front and seems mostly passenger side. My shocks are tight, the sway bar connecting link is tight......is it a dry ball joint? It seems it started early in the weekend after driving in all the snow in 4wd.
Pat
Pat
Most likely a dry balljoint. My F-150 started doing the same thing recently and I drilled a hole in each a-arm just above the balljoint, tapped the hole and thread in a grease fitting. I then gave each fitting a couple shots with a greasegun and they no longer squeak. It sure as heck beats spending $300+ for new balljoints!
Before you do that, I would check the tierods. Just crawl under the truck and try to turn the tierod back and forth. If you can make the squeak that way, it could be worn tierod ends.
My guess is that its the lower balljoints, because that sounds like the exact same thing that my F-150 was doing.
Thumper19
53
06-06-2022 06:36 PM
builtfromiron
05-28-2011 08:27 PM
Skandocious
42
02-13-2008 06:48 PM
