Need some help with my 51' F1.
I have a 51' F-100 pickup and I am just getting ready to restore it. I am debating what to do with the rear-end because it is geared so low. It still has the original 3 speed in it and a flathead me and my dad rebuilt a few years back. Do most people change the gearing and if so where can you find the gears?
Thanks,
Chris
Thanks,
Chris
Will try to post again. Chris, Welcome to FTE! From everything I have read, like havi said, the 9" is probably you best bet. I am going to change the rear end on my '50 F-1 with a 6 Cyl. so I can get a better cruise speed and lower RPMs. Hopefully, someone will chime in with more insite on the best gear ratio to choose as the 9" comes in all ranges. If you choose the wrong ratio you will be no better off.
Gil
Gil
Welcome to the forum, I installed a 69 F150 with 3.23 gears in my 51F1 at the sametime I installed the S-10 5-Speed. I had to grind out a bit of the orginal shock mount assembly. The driveshaft was the biggest most expensive part of the whole job partly because I didn't do all my homework. Junk yard shopping has really changed in the last 30 years, at least in this area. It cost me $225.00 to get the shaft modified plus a whole bunch of running around.
51chris
Electrical Systems/Wiring
06-07-2011 11:02 PM
