How many miles do you have on your Expy?
#302
1998 Expedition Eddie Bauer 4x4, almost 220k with no major problems other than the air ride suspension in the rear went bad, replacing with coils, soon though. I'd much rather take reliability over "comfort" in that area, with towing trailers and all. The driver's side window motor went out, too. Runs like a beast. has a 2.5" to 3" tip, glasspack, K and N air filter, Airraid PowerAid t.b. spacer. All fluids are current, using Mobil1 Synthetic 5w20 with either K and N or Fram TG filters. Engine cleaned regularly with Gunk Motorflush and fuel system with BG 44K on occaision
#303
Hey all, new on the forums here. I have an '03 Expy XLT just shy of 94k. The "Turd Tank" as I call her has had no major problems. At 92k, I had to replace the PCV valve and hose because I got stalled on the BLVD but she runs like shes got a five four (its only got a 4.6).
#304
309K miles on 99 XLT 5.4
No work on tranny, engine or A/C. Zero work.
Had problems w the 4W; dropped the u-joint on front wheel drive shaft on the Jersey Turnpike, replaced radiator, water pump, no heat from dash, (probably heater core), electrical issue w the driver window, replaced factory radio cuz it lost the LED display, horn shorted out and went crazy honking for no reason, (wire harness shorted at the fuse box, cant clear check engine lite, EGR issue no one can resolve...........
#305
#309
2001 Expedition, 150600, as of this morning. It had 111000 on it when I bought it two years ago. Miles have been adding up quick, with a 140 round trip to work for the last 6 months. And 500 mile round trip to my fiances for teh last yr and a half. No major issues, other than a temp sensor, and a couple of coils. It will probably need a AC compressor by next spring.
#310
#311
03 EB
109k miles..original owner
4/02 build.. I picked it up in May of 02.
Just gutted the interior. Im replacing the driverside seat cushion and redying the seat back to match with SEM dye. Looks brand new now!
Carpet is all out to be cleaned...all interior panels are out to be cleaned.
Lots of busy work but its such a great truck it deserves some good TLC after 100k miles.
While its all out, Ive searched but cant seem to find a source (if its possbile to even do) for an IPOD inerface for the Mach 6 system with OUT the AUX button or DVD system.
Anyone have any ideas.
Having the IPOD would be the icing on the cake driving it around now.
#312
#314
