Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Speed Alert for 2003 Harley-Davidson F150
Old 03-07-2008, 02:43 PM
pro-car's Avatar
pro-car
pro-car is offline
Hey Guys,
I have a customer in Australia with a 2003 Harley-Davidson F150 requiring a speed alert to be installed. I have no problem installing these (will be a VDO brand), but I require the location of the wire that provides a speed signal.
If anyone can assist, it would be appreciated heaps.
Lok forward to your response
Old 03-12-2008, 10:07 PM
commandersander's Avatar
commandersander
commandersander is offline
When you say "speed alert".....
There are 5 DIFFERENT sources, and all of them refer to a 12v pulse trigger.
If you want to do him a favor, you can pull it from the TSS and he won't EVER trip the device. The next in line is OSS, but it is a little less forgiving....it is downstream of the TSS and has a closer-to-true indication of actual wheel (or at least driveline) speed. Next in line is the VSS wire...ACTUAL tire rotation speed.....
That is a GY/Blk, pin 68 at the pcm
Lemme know what yer needin, and I send you a schematic
Old 03-13-2008, 01:12 AM
pro-car's Avatar
pro-car
pro-car is offline
Thanks for the info commandersander. All that I am after is the VSS wire so that a speed is detected by the speed alert, same as what is used when you connect a cruise control to pick up the speed pulse. Look forward to your diagram.
1967 Turbo 6.9
Modular V8 (4.6L, 5.4L)
01-25-2008 04:33 AM
BigF350
11-13-2004 03:21 AM
danlee
10-08-2004 11:16 PM
NitroHuffer
05-01-2004 06:48 AM
1956MarkII
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
12-22-2002 11:00 AM
Quick Reply: Speed Alert for 2003 Harley-Davidson F150
