Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane and Alternative Diesel Engine Fuels
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-05-2008, 03:35 PM
secondarychaos's Avatar
secondarychaos is starting off with a positive reputation.
Methanol recovery system(s)?
Hello all!
I just finished my processor and first batch, and now it's time (yes already) to start on my methanol recovery system.
does anyone have plans, pictures, descriptions available?
I've tried all the main BD sites, but none of them are accurate enough for me to try.
I have a metal 55gal drum that im storing the glycerine in. can i heat this up and route a tube out the top and thru a condensor? or does it need to be more complicated?
thanks!
__________________
1996 Ford F250 powerstroke diesel
Running 285/75 Bridgestone dueler revos
Gauges: boost, pyro, tranny.
15.6K ICP
140V IDM mod... easy as pie
6637, 3" downpipe to 3.5" turndown right after t-case. EGT's wont go over 1100, boost to 25 psi, sounds awesome!
I think i have AB code injectors!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-05-2008, 04:42 PM
fabmandelux's Avatar
fabmandelux has a great reputation on FTE.fabmandelux has a great reputation on FTE.fabmandelux has a great reputation on FTE.fabmandelux has a great reputation on FTE.fabmandelux has a great reputation on FTE.
Yes, you can boil off the MeOH directly from your 55 gal drum with the addition of a simple condenser. The problem is the Btu's required to heat the glycerol. You would be better off using a smaller tank, and doing smaller batches.
I used to use vacuum to remove the MeOH at a lower temp, but you need a "pressure- vessel" not a thin 55 gal drum.
I've since switched to a completely different system, which I cannot get into here...................
I recover all the excess MeOH from my glycerol AND the biodiesel.
__________________
FABMANDELUX.
Don.
To join the Oregon Chapter, click HERE
'Auto racing aside, we need look no further than the Wright brothers for an historical precedent that shows the maner in which the self-taught can tread the path to sucess" Philip H Smith.
  #3 (permalink)
Old 03-05-2008, 05:22 PM
I'd be careful with that,
Cant you reverse the reaction if you do it that way,
Ex: change the equilibrium point?
How long have you done it that way?
Dan
__________________
15.6K ICP
  #4 (permalink)
Old 03-05-2008, 10:11 PM
I recover the MeOH in seperate operations AFTER I remove the glycerol from the bio.
I recover the MeOH from my biodiesel before using my dri-wash ( Magnesol)
I've been making and using bio on my ranch for almost 5 years now
__________________
FABMANDELUX.
Don.
  #5 (permalink)
Old 03-06-2008, 11:33 AM
oh, ok, i guess i have no room to be questioning you... really, 5 years?
What is this magnesol wash i keep hearing of?
__________________
15.6K ICP
  #6 (permalink)
Old 03-06-2008, 11:43 AM
Phydeaux88's Avatar
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
[quote=secondarychaos]What is this magnesol wash i keep hearing of? /QUOTE]
Check this ou it will answer most questions about Magnesol.
http://www.fryerpower.com/store/page1.html
__________________
1996 F250 4X4 Crew Cab: Diablo Flip Chip, Powershot 2000, Hypermax exhaust turbo back, Tymar AIS, All the gauges, Bilstein Shocks, AirLift Super Duty bags on the rear
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
