Does a 5.8L engine make sense in an F350?
Originally Posted by hughjazz
I'm calling B.S. The only way a 7.5 4x4 will get 15 mpg is if it is attached to the back of a tow truck. Or sitting on top of a trailer.
They practically use fuel parked with the ignition off........ 15 mpg Sheesh. You would have a hard time getting that in a f150.
Sounds like the diesel guys that get 28 mpg towing a 15'000 5'er
I think I would tend to agree on that one. I Know of 2 people who had 460 powered trucks, one was a 96 F250 4x4 supercab longbed, and another was a 94 f350 4X4 crew cab long bed,neither of which got more than 10mpg loaded or unloaded.
Having that said, I think a 5.8L may be enough to move the truck decently, but it wont be fast for sure. With that kind of mileage, it is going to be pretty tired. Weight wise, they are not as heavy as the current superduties, heck, my cousin's 92 F350 dually diesel 2wd weighs 6200lbs scaled at a yard, which is about as much as my gas 2003 superduty.
Originally Posted by superduty4x4
Say what you want, but I'm not lying. Going 65 mph on the highway it would get 14 consistently. It had 3.55 gears too which probably helped. It's not that unheard of to get mpgs like that when EMPTY with a 460, you just have to drive it nice. Go to the 87-96 forum, there was a post a few weeks back about mpgs and several of the 460 owners were reporting mid teens consistently.
Also on topic, anyone that I've talked to didn't like the 5.8 in anything bigger then a half ton, so I vote that you hold out for the 7.5.
Thanks for all the input guys. It really helps to hear other peoples experiences and knowledge. I think I will wait until I find a 460 or maybe a 7.3 with lower mileage. I hadn't thought about the tranny. I won't be using it daily but I do want the power when I do haul. The F250 with the 302 just doesn't do it so I don't want to make that mistake again.
Thanks again for the advice.
To answer the original question : Yes, a 5.8L does make sense in a F-350. However, a 7.5L(460) makes even more sense in a F-350. I've had both engines...in F-250HDs, not F-350s, but both had 4.10:1s and E4OD trannies, and the 460 would out pull the 351, and was quicker when unloaded. We also had a 351 in a Bronco. It couldn't out run our 460 pickup.
I have a 95 F 350 4x4 regular cab with the 5.8, E4OD, 3.55's, and 265/75-16's(same height but a little wider than stock 235/85-16's). I have never gotten better than 13 with this truck, ever. It gets about 10 in the winter and 11-12 in the summer on average. I have had this truck for about 5 years, and have put about 30k on it. I would trade this thing for a 460 anyday. It is not bad to just drive around, but if I tow it is a slug. Had an 03 F 150 4x4 5.4 with 3.55's that was rated to towabout 1300lbs more than my F 350 according to the manuals. If I was to do it over again I would look for a 460 or a Power Stroke.
Steve
Steve
Steve
Steve
Well one thing we all agree on is that a powerstroke especially an obs one is the ultimate choice. you would get great mileage with it..
Personally my 5.8 with a 5 speed and 4:10 was able to move 20'000 all day everyday for a couple years.... All I know is I would never get a 460 again. I sold the truck I was so disgusted with it. Over $80 a day in fuel to do my deliveries (sometimes closer to $100) Doing the same with the 5.8 I was just over $50...... $30 a dayX 22 working day a month i COULDN'T AFFORD THAT THIRSTY PIG. anyway a powerstroke would have made it under $40. But was worth $5000 more
Steve
I don't think that 5.8 has too much life left in it. All depends on what you are towing. It is a more powerful motor than the older 5.0, but it isn't all that for a heavy duty truck. I didn't know you could get the 5.8 in a crew cab back then. Is it a long or short bed? That is a lot of truck for that motor.
#29
