year tailgate?
Old 04-12-2010, 02:42 PM
mortalis09's Avatar
mortalis09
mortalis09 is offline
thats ok i have no idea what mine is and where the trim badge goes i just have a slightly less faded section of paint under the f150 lol
  #62
Old 04-12-2010, 07:11 PM
Festus Hagen's Avatar
Festus Hagen
Festus Hagen is offline
Methanoholic
Apparently I'm not getting my point/hopes across ...
I understand they all look the same without trim (80-86).
I understand the hardware difference between the 80-82 v. 83-86 -96.
Anyone that can't figure that out by now hasn't read the thread, it's been beat to death!
What one (or at least I) cannot figure out of this thread is what the trims are and what trucks they came on.
-Enjoy
fh : )_~
  #63
Old 04-12-2010, 07:30 PM
first today's Avatar
first today
first today is offline
I understood what you were going for. You want to know what year or years ran the trim panel on the tailgate and the level of the truck.
Mine is 1983 XLT. I only have trim on the tailgate, along the bottom of the two tone, and the trim around the grille/headlights. Chrome bumpers also. Plain argent grille originally on mine.
I have seen different trim panels on the trucks also. Did some have just chrome trim across the top and bottom of the tailgates?
  #64
Old 04-12-2010, 09:55 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
81-F-150-Explorer is offline
Yes, there was a thin piece of trim that went along the top of some tailgates with the tu-tone package. Tu-tone was avaliable on any model or trim.
The tailgate trim panels being looked at are specific to the following years... This is not referencing the tailgate itself, just the trim piece on the gate.
1980-1981: Ranger Lariat
1982-1984: XLT Lariat
From the 1981 brochure:
http://www.lov2xlr8.no/brochures/for.../bilder/11.jpg
1985-1986: XLT Lariat:
https://www.ford-trucks.com/user_gal...id=228424&.jpg
  #65
Old 04-16-2010, 01:37 AM
Festus Hagen
Methanoholic
If you have this gate and trim and you pull the trim off
Will it look like this ... Of course it'll have the trim holes and probably no white paint on the lettering.
Thanks.
-Enjoy
fh : )_~
  #66
Old 04-16-2010, 06:34 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
Yep. Depending on whether the gate is an original or replacement, it may not have the stamped letters though.
  #67
Old 04-16-2010, 07:59 AM
Festus Hagen
Methanoholic
If it's a OEM (Ford Factory, Not re-pop) gate it WILL have the stamped letters correct???
-Enjoy
fh : )_~
  #68
Old 04-16-2010, 08:13 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
YES. all FORD gates up to and including 91 had the ford stamped into it, weather it had the aluminum on it or not. In 92 they started the smooth gate without the FORD stamped into it
  #69
Old 04-16-2010, 08:48 AM
Festus Hagen
Methanoholic
I thought that, It's logical, Just wanted it stated clearly from someone that knows more about these trucks than I ...
I buy the wrong gate and I'll have to live with the wrath of the ol'lady for my remaining time on this earth!
Don't forget, I'm only a year+ into Fords!
Thank you all.
-Enjoy
fh : )_~
  #70
Old 04-16-2010, 09:02 AM
Chitownhillbilly's Avatar
Chitownhillbilly
Chitownhillbilly is offline
Thanks.
-Enjoy
fh : )_~
For what it's worth, mine has the white paint.
Another question... Does anyone reproduce the Red reflector piece that goes on the aluminum trim like the gate above?
  #71
Old 04-16-2010, 09:27 AM
Rogue_Wulff
Man, I'd kill to have a tailgate that is that straight, and not coming apart at the seams. Mine is close to that straight, but the ends are pulling apart badly. Not sure I can fix it and make it look good. One or the other, no problem......
  #72
Old 04-16-2010, 09:48 AM
Festus Hagen
Methanoholic
That image is just an imaged I ripped from the web, I didn't really want to post it for that reason.
I am looking at one that's in better shape (it's a brand new stored pull from a camper lot), and has the trim like the other image in post #65.
-Enjoy
fh : )_~
  #73
Old 04-16-2010, 02:47 PM
81-F-150-Explorer
No, the red reflector piece is a part of the aluminum trim, it has to be bought together.
And no one is reproducing the aluminum trim panel either.
It's a very sought after, and expencive little piece in NOS condition.
  #74
Old 04-16-2010, 02:58 PM
fellro86's Avatar
fellro86
fellro86 is offline
I took one, drilled holes from the inside ends of the gate, then plug welded the pieces back together. I did it at the inside curves of the center structure rather than at the outer edges and it held up to being used as a work bench... Only reason I don't use it right now is because the pivot mount rotted off the box, so there is nothing to hold the gate up when you open it... Sure, doing this will burn the paint, but there really isn't any way around that.
  #75
Old 04-16-2010, 04:36 PM
Diesel_Brad
I bought 2 NOS tailgates last year for 400 a piece
Quick Reply: year tailgate?
