Cutting an 05 grill to fit a 99-04
#47
#48
Subscribing to thread....BTW I called Certifit today and that price was around 50 bucks for the grill. How much of a pita is it to change out the header panel? I'm pulling the raditor and intercooler soon to do the front crank seal so i might as well do this mod at the same time.
I want the shiny grill. Me like shiny.
Seems kinda crazy to pay $200 plus shipping for an aftermarket grill which they cut up, when you can buy a grill for $75 and cut it yourself....
#49
I called Certifit in Baltimore and they only sell the black grill for the 2005-2005 superduty. Go figure....the guy told me the late model superduty parts are limited. Black grill is only $55.
#50
#51
#52
I used this harness....
Headlight Conversion Harness [50-917-8] - $85.00 : GOS Performance | High Performance Diesel Parts | Bozeman / Livingston, Montana, 800-620-4467
I'm very happy with how this mod turned out. I like the chrome look of the bumper better than the 05 painted one.
#53
#54
#55
I installed it two years ago and it came with the emblem. Expensive yes, but it turned out ok. I just didnt trust myself to make a straight cut..
#56
Yes, it fiberglass. I used a roto zip and the instructions you see earlier in this thread. That harness uses relays and is connected directly in the batteries for voltage. Plus, high beams gives you both high and low. My old headlights were clouded, bad. You can do this easily in 4 hours.
#57
So you use OEM 2006-2008 headlights? + the harness?
Do you feel like the new lights are secure even though they aren't using the factory mounts?
#58
New 99 04 Superduty Excursion Conversion 07 Headlamp Headlights Set 00 01 02 03 | eBay
#59
I don't see the point of that complex $85 harness when you can get the lights and the wiring for $160.
#60
KEYSTONE, do they sell the public? Aren't they an LKQ Corp subsidiary?
