is this a lincoln 332?
Hi everybody i,am new today on this forum.I,am Hans from the Netherlands.
Who can tell me if this is a lincoln 332?
the serial plate says Ford industrial engine
B6PL-6003-c
engine cast numbers are ect-c and also the cylinderheads,intake valves are 2 inch, cilinder bore is 3.8 inch dont know stroke yet because they are stuck in the engine camshaft mains are 2.62 and rods are 2.25.
camgear is gear driven not chain.also the watertpumphouse is diferent than the usual ford y block .Its fitted with a holly 2bbl teapot carb with cenrty vac.
If any questions i can sent photo,s
Thanks already
B6PL-6003-c
Thanks already
Hello Hans!
Try posting your question here: https://www.ford-trucks.com/forums/forum51/ This forum is used for introductions and that link will take you to the big block forum.
