New Hampshire Chapter Join Chapter Leader: 7283-F250
Courtesy Ligths
Old 02-23-2008, 01:15 PM
JD1036's Avatar
JD1036
JD1036 is offline
Courtesy Ligths
I have installed two 6 bulb l.e.d. ligths in the upper part of my running boards directly under the driver and passenger doors, this is a 2006 f150 super cab there are no buttons in the door frame to work the inside ligths. this truck does have a dim down mode. I would like to find the best point to tie these ligths in so that they will work then the doors open?????????
JD1036
Old 02-24-2008, 01:53 PM
7283-F250's Avatar
7283-F250
7283-F250 is offline
I would post this question in the correct year f150 section of the forum. You will get a lot more people to respond and probably get at least 3 different ways to hook them up.
and
WELCOME
Old 02-25-2008, 11:51 AM
JD1036's Avatar
JD1036
JD1036 is offline
thanks for the information ,will give it a try.
jd1036
