2003 F150 Front Bearings
Old 06-16-2008, 01:55 PM
OLDEAGLE's Avatar
OLDEAGLE
OLDEAGLE is offline
This is my first post here so if I seem a little nervous, I am.
I am looking to replace the front drivers side wheel bearing hub on my 2003 F150 supercab 4X4 and I must admit I am a little apprehensive about it.
I have heard that the old hub can be near to impossible to get off, is this true and if so any tips on how to do it.
Also other that a new hub assembly do I need to replace any other items while I am in there. ie: seals or bushings?
Old 06-16-2008, 04:39 PM
KingRanchMan02's Avatar
KingRanchMan02
KingRanchMan02 is offline
Welcome to FTE OLDEAGLE! Read the "Read this first" thread at the top of this forum. there is a very good thread with pictures on how to do this job there. it is at the very bottom of Racerguys initial post titled How to replace the ball joints on your 97-03 F-150 4X4
Good luck!
Old 06-22-2008, 07:08 PM
fordguy23's Avatar
fordguy23
fordguy23 is offline
I changed my drivers side hub assembly, and getting ready to do passenger side. I had no problems changing mine out on the drivers side. I sprayed all my nuts and bolts with pb blast, and they all came right loose. Good luck!
