Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southwest Region > Arizona Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Arizona Chapter Join Chapter, Leader: Bill W
  #1 (permalink)
Old 02-16-2008, 09:02 AM
firegatejee firegatejee is offline
Garage is empty, add now
firegatejee is starting off with a positive reputation.
75 ford help
Hello i have a 75 ford f150 2 wheel drive with the 390 i am trying to put a 3 inch body lift on it and it is giving me trobles with the steering it all went on but when i was done the gear box and the cupler going to the steering wheel did not line up and the gear box is closer to the cab so i am trying to see if there is anything i can do to move or put something there to make it work
  #2 (permalink)
Old 02-16-2008, 09:44 AM
Born Blue Bob Born Blue Bob is offline
Born Blue Bob is starting off with a positive reputation.
With body lifts the steering collum and shaft goes up with the cab causing it to pull from the steering box which is tied to the frame. If you ordered a body lift from a well known distributor they will also supply an "extension" or coupling to make up for this difference. I ordered my body lift from Performance Excessories for my '92 and it was supplied with the kit. You may also want to peak at other trucks of this era that have a body lift to see what was utillized. Good luck!
  #3 (permalink)
Old 02-17-2008, 12:53 AM
kermmydog's Avatar
kermmydog kermmydog is offline
ARIZONA CHAPTER
1995 Ford F-150
kermmydog has much to be proud ofkermmydog has much to be proud ofkermmydog has much to be proud ofkermmydog has much to be proud ofkermmydog has much to be proud ofkermmydog has much to be proud ofkermmydog has much to be proud ofkermmydog has much to be proud ofkermmydog has much to be proud of
Welcome to the both of you from the Arizona Chapter. Where in Arizona are the both of you from?
  #4 (permalink)
Old 02-17-2008, 02:09 AM
safford az
Tags
firegatejee
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
