Methanol recovery system(s)?
Old 03-05-2008, 02:35 PM
secondarychaos's Avatar
secondarychaos
secondarychaos is offline
Hello all!
I just finished my processor and first batch, and now it's time (yes already) to start on my methanol recovery system.
does anyone have plans, pictures, descriptions available?
I've tried all the main BD sites, but none of them are accurate enough for me to try.
I have a metal 55gal drum that im storing the glycerine in. can i heat this up and route a tube out the top and thru a condensor? or does it need to be more complicated?
thanks!
Old 03-05-2008, 03:42 PM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Yes, you can boil off the MeOH directly from your 55 gal drum with the addition of a simple condenser. The problem is the Btu's required to heat the glycerol. You would be better off using a smaller tank, and doing smaller batches.
I used to use vacuum to remove the MeOH at a lower temp, but you need a "pressure- vessel" not a thin 55 gal drum.
I've since switched to a completely different system, which I cannot get into here...................
I recover all the excess MeOH from my glycerol AND the biodiesel.
Old 03-05-2008, 04:22 PM
secondarychaos
I'd be careful with that,
Cant you reverse the reaction if you do it that way,
Ex: change the equilibrium point?
How long have you done it that way?
Dan
Old 03-05-2008, 09:11 PM
fabmandelux
I recover the MeOH in seperate operations AFTER I remove the glycerol from the bio.
I recover the MeOH from my biodiesel before using my dri-wash ( Magnesol)
I've been making and using bio on my ranch for almost 5 years now
Old 03-06-2008, 10:33 AM
secondarychaos
oh, ok, i guess i have no room to be questioning you... really, 5 years?
What is this magnesol wash i keep hearing of?
Old 03-06-2008, 10:43 AM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
[QUOTE=secondarychaos]What is this magnesol wash i keep hearing of? /QUOTE]
Check this ou it will answer most questions about Magnesol.
http://www.fryerpower.com/store/page1.html
F350FordToy
6.2L V8
07-21-2021 07:50 PM
Rushmore X
Bio-diesel, Propane & Alternative Diesel Engine Fuels
08-06-2017 10:40 AM
scottperkins
1997 - 2003 F150
06-29-2016 10:33 PM
gi1gamesh
6.7L Power Stroke Diesel
06-04-2015 03:27 PM
Quick Reply: Methanol recovery system(s)?
