Modular V10 (6.8l)
New member help on exhaust
Old 11-27-2014, 11:30 PM
hollyridge34's Avatar
hollyridge34
hollyridge34 is offline
First off I'm a new member, lots of great info. Got my first SD a 99 f250 v10. practically stole it. Been upgrading in my garage the last couple weeks. elc coolant, new hoses Ball joints, tie rods, all new front and back bilstein 5100s, 37 inch Goodyear mtr's. anyways I'm looking redo the exhaust has duals right now but they have ****ty welds and mismatched pipes.
I'm looking at the mbrp 4" inch stainless dual exhaust, exhaust manifold bolts are broken so I might as well do the headers and y-pipe too. where would I find those eBay headers for $200 everyone talks about? all I can find in that price range is this F 150 Pacesetter Shorty Headers 70 1326 | eBay
Is that correct?
Old 11-28-2014, 07:57 PM
WE3ZS's Avatar
WE3ZS
WE3ZS is offline
World Famous Mod
If you search around here a little you will find several users who had the ebay headers fail from cracks (with some making repairs only to have them fail again). I would look to spend a little (or a lot) more $ on better headers with a Y pipe, my Banks stainless headers & Y pipe ran me $850-ish and provide noticeable performance gains from just off idle to redline, that is with the headers and Y only, the rest of the exhaust including cat is bone stock. I'm not an exhaust expert but I feel that the factory 3" mandrel bent pipe is pretty good and going to a 4" single or larger may actually reduce performance slightly, but what do I know....??
Old 11-29-2014, 12:56 AM
twigsV10's Avatar
twigsV10
twigsV10 is offline
If you're going to replace a "****ty" exhaust job don't replace it with another " ****ty" exhaust job, cheapest isn't the best and the most expensive isn't always worth the money but the one with a good reputation is a good place to start.
As far as the exhaust size after the stock cat I don't think it makes any difference in power just noise but high flow cat or and for those who go that way no cat that's arguable. I personally can't quite wrap my head around how freer flowing headers are good for power but freer flowing exhaust after that is bad?
Old 11-29-2014, 08:11 PM
V10man's Avatar
V10man
V10man is offline
Those headers aren't even for a V10. Banks, Doug Thorley, Hedman, all have new Y pipes. JBA, Gibson, the other shorties do not but may work well with the Y pipe mod.
Single 3" or dual 2 1/4 to 2 1/2" is plenty big for a V10. It's only 415 CID. Too big exhaust actually can cause loss of flow, turbulence etc. As the exhaust cools it slows down so a smaller tail pipe keeps it moving. Moving exhaust also scavenges which helps clear the cylinders.
Old 11-29-2014, 08:36 PM
hollyridge34
Ok so if I go with the Thorley 218y-c long tube headers it comes with a y pipe and all I would need is a catback exhaust? I'm wondering because my truck never came with a cat and it passed inspection so I guess I didn't need it? I could just use pipe as a connector correct? Borla and mbrp are both 4" I'd like to stay with duals, is flow master the only other choice?
Old 11-29-2014, 08:59 PM
V10man's Avatar
V10man
V10man is offline
dynomax has a dual cat back as well as Magnaflow I believe.
Beau_2003
Modular V10 (6.8l)
15
02-25-2010 06:06 PM
bobbyt89
11-02-2009 06:14 PM
Rays98govols
Exhaust Systems
06-27-2008 02:55 PM
nucleartruck
Exhaust Systems
04-07-2004 08:16 PM
kbkid
Exhaust Systems
03-25-2004 07:12 AM
Quick Reply: New member help on exhaust
