paxton on a 460?
paxton on a 460?
I'm thinking about fitting a SN89 6psi boost supercharger(from a mustang 5.0) on my 460 ford. The heads I have is the D3VA, so because of the 92 cc comb. chambers the compression ratio would be good for this setup.As for the carburator I'm planning to use a 750 Holley w/ vac secundaries. The intake would be a Edl. Performer.What cam can I use for this setup? The car will be used for the street. Not for pulling or so.
I'm planning to use the stock 460 pistons, as because engine won't rev past 5500rpm. What else should I have to do to the engine to accept this?
Please help.
Thanks , Jack
Please help.
Thanks , Jack
