what is the best way to block off the heat crossover passages from the cylinder heads going into the manifold, special gaskets available, or just cut a piece of stainless sheet metal & sandwich it in between?
any ideas?
Rick
yeah, I thought about doing that but wondered if the exhaust heat would just burn the epoxy away.
I guess it would still be ok because the piece of metal will be held by the gasket.
thanks for the reply,
Rick
