What is rear spacing on wheels?
Series Wheel
Finish: Black
Size: 17'' x 8''
Bolt Circle: 5 x 5-1/2''
Rear Spacing: 4-1/2''
In your opinion which wheels will fit better and look good? If, neither of these sizes then what would you recommend? I want to upgrade from the current stock 15 inch rims on my 1979 Ford F100 2wheel drive. What Rear Spacing do I need as well?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Series Wheel
Finish: Black
Size: 16'' x 7''
Rear Spacing: 4''
Finish: Black
Size: 17'' x 8''
Series Wheel
Finish: Black
Size: 16'' x 7''
Rear Spacing: 4''
Take off one of your wheels and lay a ruler or something across the backside of the rim. Measure the distance from the lower edge of the ruler to the mounting flange of the rim. This is the backspacing.Too little, and the tires will stick out past the fender. 4 or 4 1/2 should be OK. I have 8" wheels with 4" and they fit just fine.
Planning on lowing the rear 4 inches. This is what I want to put on the back of my 74 F100. Think I'll have trouble?
http://store.summitracing.com/partde...2D5055&FROM=MG
Don't know if you have a Flareside or not, but I have 15x10's with 6" of backspace on mine, Mickey Thompson N50-15 tires (14'' wide) and they're inside the fenders . . . . barely! 15x8's with 4" of backspace on front, Mickey Thompson H50-15's (12" wide). Again, barely. I've got 2" between the tire and the rear spring.
The front wheels are "off the shelf" American AR-767 wheels. The rear 15x10's I ordered from Stockton Wheels in California. They just happen to look "exactly" like the Americans. They are Stockton's "Explorer" series. They were $105 ea. plus shipping back in 2003. Who knows what they are now! Trim rings were from Pep Boys. I dropped the rear about 4" or so and cut a coil and a half out of the front springs (I think!). Anyway, I like it!
If you want a 10" wide wheel you need between 5.5 and 6" of backspacing especially if you lower it. I have 15x10s with a 325/50 drag radial and they just fit with 5.75" backspacing. I also had to hammer the wheel well in to get them to fit but any less backspacing and they would rub on the outside even with the lip rolled.
Originally Posted by leshall89
droppedf100, are your rear wheels custom built or off the shelf?
