More Trans Problems... TS Chip related
Originally Posted by mattg
I have a TS 4 position chip from TW. It does the same thing but only in the "performance" setting. The "tow" setting works great! Although third hits a little hard sometimes. I figured it was just a programming issue and had planned to take it back to have him program the "tow" shift program with the performance tune. I hope that fixes it! For now I just shift it manually in performance and it works fine.
Matt
Matt
-Robb
Right, I was saying that mine only shifts hard into third on "tow mode". Not even worth mentioning really. Other than that everything else transmission wise works great on "tow". But when it's on "performance mode", that's when I get the "upshift/downshift/TC-slipping" you were talking about. It's really annoying! That's why I suspect it could be a programming issue. Because it seems like it would shift bad in any position if there was something wrong. I dunno though, I'm just guessin.
You can install an led lamp so you can see the TC lockup.
This is what could be going on.
In the performance mode the chip could be locking the TC in the lower gears. Some tuners burn it this way.
What you feel is the TC taking to long to unlock and lock. The gear shift (3rd) itself is quicker than the TC. It sort of feels like a double shift under throttle.
Installation of the led will allow you to see it. You can also see it in a realtime scan.
This is a common problem in the E4OD for the 4th OD shiftpoint. I believe yours does this in the 3rd shiftpoint for the same reason (2nd gear tc-lock)
Here is a vid of c00n's doing it in the OD shiftpoint.
Yours will do it in 3rd and/or 4th
http://www.youtube.com/watch?v=QzF6CH5CIR4&NR=1
My shiftpoints--1,2,3,tc lock,4
http://www.youtube.com/watch?v=D-6Fvm-12tQ
Bill
Bill
-Robb
Alright humm... so is this a problem felt by everyone that has a chip with performance burn that hasn't worked through it? Thanks you for your help so far... looks like I might be sending the Chip back... Just can't believe it THAT bad out of the box, I can't imagine that it's good for truck or trans to do what it does...
-Robb
-Robb
Alright Bill thanks for the help! I'll give that a shot. Not going to be able to get to my truck until Wednesday or Thursday. Right now my Engineering classes are taking up the majority of my time. I'll let you know how things turn out. Also in contact with TS to try and get this issue sorted out. Thanks again
-Robb
-Robb
#28
OK SO! went for a test spin today, because it was driving me nuts. On the gas about 3/4 throttle and locked TC after 2nd. No weird up-shift/down-shift/tc-slip, however going into third felt "sloppy" for lack of a better word. What course of action should I take? have it sent back and changed from a "pref" burn to "tow"? if in "tow" mode will the truck shift at higher RPM's even with a light throttle? I don't want to run into that issue either. A happy medium would be good. Thanks!
-Robb
-Robb
#29
#30
Humm. So I'm still not sure what the best solution would be. I don't want to have high rpm shifts if I'm just cursing around town and going for fuel economy, but I also want to get rid of this sloppiness. What would your recommendation be? is there a possibility that the TC is going out? truck has 150K..
-Robb
-Robb
