seized 460
seized 460
hi guys, i just picked up a 77 f250 supercab with a 460 that was supposedly running until 2 weeks ago when the guy i bought it from drove it home and parked it. when he went to drive it 2 days later it wouldnt crank over, you cant even bar it over by hand, any ideas? according to him it wasnt running hot or making any unusual noise, and i checked the oil and it looks fine, and the coolant level is good.
True. Should be a ~10 minute job to get it off, and is a good place to start checking.
If it is the starter that came apart and is jamming up the flywheel, how would you get it out without destroying either the flywheel or the bellhousing? Just attempt to spin it the opposite direction of the jam, then try to fish it out with a magnet?
~B
~B
I have seen this very thing...several times....and each time it was on a Ford with a remote-located solenoid type starter. I'm betting this is exactly what's happened here.
i didnt take the time to plastigage the clearances, but i did replace all the main and rod bearings. both i and the machinist i got the rod from came to the conclusion that the old bearings were standard as we couldnt find any markings otherwise and they were stamped ford. the only thing i can think of that i might have a problem with is the fact i couldnt find a parts store with a oil pump gasket in stock so i used a light coat of rtv instead, could it be blowing by that once it warms up?
