Help me set timing on my Thunderbird for bracket racing!!!
Hey guys,
I have a 1972 Thunderbird with the low compression 429 4V engine. Other than an Edelbrock 750 manual choke carb, the engine is completely stock (I'm running exhaust manifolds into duals). I don't have access to a timing light at the moment, so I'm looking for suggestions on setting the timing by ear. I was told that if I plug the vaccuum advance and have my friend hold the engine around 2000-2500 rpms that I should advance the timing until the engine starts pinging and then back off. Well, I can advance the timing until the rpm's drop off and then the idle is surging once I let the car come back down to idle, but I can't seem to get the engine to ping. Will I not be able to achieve pinging because my compression is so low and because of the 8 degree retarded timing set? I'm assuming that spinning the distributor clockwise is advancing the timing, right? If I try to adjust the timing at 2500 rpms (or even at idle, for that matter) to where I get the highest/smoothest rpms, I seem to end up too far retarded overall.
Thanks guys!
--Steven
Thanks guys!
--Steven
compman
12-22-2013 09:23 PM
1972 Ford Thunderbird 429 V8
03-26-2003 07:55 PM
01-15-2003 05:24 PM
10-06-2002 11:23 AM
02-07-2002 11:10 PM
