vaccume secondaries vs. mechanical
Old 10-24-2007, 09:30 PM
6t56's Avatar
6t56
6t56 is offline
I put a edelbrock 600 cfm with mechanical secondaries on my 477.It came from the factory with a holley that had vaccume secondaries.Will the edelbrock dump in to much fuel because the secondaries are forced open?The engine is running really rich,blowing flames out the exhaust and running really bad.Is it better to have vaccume secondaries on this particular engine?
Old 11-10-2007, 06:59 PM
amish77's Avatar
amish77
amish77 is offline
Depends on application. If you are racing this thing only, then mechanical are the way to go. Street use usually goes with the vacuum secondaries. What is your timing/cam setup? Seems like it's gotta be more than just richness to blow flames out the exhaust.
Old 11-19-2007, 07:26 PM
57Fitzjohn's Avatar
57Fitzjohn
57Fitzjohn is offline
sorry thought you were talking 534. Disregard.
Last edited by 57Fitzjohn; 11-19-2007 at 07:30 PM. Reason: non relevant info for this post
