Vibration At Highway Speed
Just wondered if anyone has tried the TSB 05-13-1 on there f150 ?Mine is a 2004 xlt 4x4 and it shakes and vib really bad from 55 to 60 mph ,had tires balanced 3 different times brakes repalced and rotors turned ...This is driveing me nuts tring to figure this one out ...
Originally Posted by wildman f150
Not the parking brake checked them both when had my brakes done ,also checked for a hot wheel after driveing none of them are hot ....Has anyone tried changing pinion angle with TSB 05-13-1 Just curious
Vibe is more in the seat you can actually look in the rearview mirrior and see the whole bed of the truck bounceing and viberating up and down ,but only does it at between 55 and 60 whether in o/d or not .Been there since I bought the truck this summer took it back to the dealer they put a new driveshaft in it helped it some but seems to be getting worse now ...
Mine was fairly bad, I thought for sure it was a seizing u-joint. The road force fixed it.
In your case one way to eliminate the tires would be to move the rear tires to the front. If it is the tires this should move the vibration to the steering wheel / floor pan. Process of elimination I guess. Its tough to diagnose a 4x4 for highway vibration.
on
I had the same problem with my 06. The dealer force balanced my first set of continentals. The dealer then replaced them with another set and force balanced them, the vibration and bed bounce was gone.. I had no problem with the second set until a few months ago...
The bed bounce and vibration was back.. I checked the tire pressure and it was 4 psi low. (Sometimes my truck sits for a month between outtings.) I aired them to the correct pressure and the vibration and bounce were gone again..
