300th. post... and i have a ???
hey guys i checked my gpr today and i bridged it over with a screw driver and i tested it with a tester... and i know some of you say it throws alot of sparks when you bridge it with a screw driver... right??? well mine just barely arc'd... could this be bad gp's... or am i just wanting to tear into the valve covers??? and what would happen if i took out the gpr and just put in a switch with wires running inside the cab and hit the switch to turn them on when it was cold??? would this work or is it a bad idea all together???
Originally Posted by powerstrokeddiesel
well guys i just did a little bit further testing and it is not the gpr or atlest i think... ok when the key is off one of the top post have power... and with the key on both should have right??? and this also means good gpr right???
erichy
01-14-2012 08:57 AM
ncline
12-17-2011 09:41 PM
Bobbys Big Red Rig
16
11-21-2010 04:52 PM
97ExpGuy
1997-2006 Expedition & Navigator
07-10-2010 11:56 AM
PaysonPSD
12-21-2007 11:31 PM
