XM Radio Installation Questions
I am considering installing XM Radio onto my 06 Super Crew 4x4 Lariat. I have read past posts on this. I am planning on installing the PIE adaptor and hopefully using the Audiovox Terk Commander which will fit in the ash tray. Now my main question is when using the PIE adaptor, will it plug directly into the XM wiring? It also says you can use it for an IPOD. My main question is how the PIE adaptors plug into your XM unit or IPOD unit? Any info and ideas regarding XM radio installation onto our trucks is greatly appreciated. Thanks....
I used a PIE adapter on my '01 Expy. If memory serves I believe I used standard composite inputs (red/white). The XM Commander has a separate module that goes behind the dash (or under the carpet, under a seat, where ever) that has a composite output. That goes to the PIE. The PIE I used has an on/off switch and when it was on if you hit the am/fm button three times it would go over to auxiliary/sat.
