How much would a 92-96 f150 weigh empty with a 351w, overdrive tranny, long bed, 4x4, reg cab, and dual tanks. How do they compare in weight to an 84 f150 with basically the same set up?
Consumer Guide's review of the '90-96 F-150s shows the '90 regular cab long bed 4x2 at about 3975 lbs if I remember right. I'd guess 4WD adds 200-300 lbs. I don't remember seeing what engine their model had, but I think the 351 is not much heavier than the 302 (maybe 50 lbs.?), nor is it much heavier than the 300 six.
If anything, I'd have to guess an '84 would weigh about the same, maybe even a bit heavier owing to more metal in some places than the '92-96 models. Just a guess on that, though.
Thanks for the replys. I was guessing at around 4000 to 4500 lbs. I can't remember exactly but I weighed a 1991 explorer on co-op scales and it was either 4000 or 4400, I can't remember, and didn't figure the f-150 would way to much more considering it doesn't have all the carpeting and extra seats and the extra weight of all the metal and glass that encloses everything.
Look inside the driver side door, there is a badge that will tell you
The GVWR (gross vehicle weight rating) is not what the vehicle weighs, it's the max capacity of the vehicle (full weight) under load. So that is the maximum weight that truck can be when loaded.
Most of you guys will find yourselves better off than I am, GVWR-wise. My truck is rated at 4900 lbs.! So, once you add myself, my three-year-old son and 1-year-old daughter (they're almost ALWAYS with me!), I can haul about 700 lbs., which is !!!
builtfordtough13, why would you say that the 92-96 weigh more? Do they have something extra that would weigh more? Are they slightly longer or taller so there is more sheetmetal or what?
