429 thunder jet
on
its possible, but as far as pratical, maybe not.
the fuel injected heads and intake are different from the earlier stuff, so you would have to change the heads, intake, exhaust and distributor to the fuel injected stuff. if you are doin that, you may as well just get a complete fuel injected 460 instead. you will also need the computer, wiring harness and a high pressure fuel pump to make it all work. then you will have to figure out the wiring harness and adapt it to your vehicle properly.
another alternative is to use one of the aftermarket fuel injetor kits on your 429 instead. like the Holley system or other comparable systems. a lot simplier in the long run but not cheap.
rgds
Mike
rgds
Mike
thanks
thanks mike for the info, i do apperacate it. im puting it in an 87 f250 that had a fuel injected 302 in it. i will look into the aftermarket fuel injector kits. any other info or ideas i would like if you have any, thanks again. tory
rgds
Mike
rgds
Mike
