99 F-350 V10 question?
1999 F-350 4x4 Crew Cab V10-174,000 miles
Left work and drove only a mile or so and noticied that the temp gauge hadn't moved yet, then all of a sudden it pegged itself in the red and the exhaust was blowing white smoke, went another block and pulled of road and shut it off, rad. reservior was bone dry. went to store and poured 1.5 gallons of water in the system, started up and smoked just a little, got home and flushed system twice and poured in BLUE DEVIL and it seemed to solve the problem (as far as exhaust smokin) It's now been 2 days and no fluid loss. Here's the 2 problems- I keep hearing a ticking noise from engine comp. at about 2000 rpm/45-55mph, It's not noticable at idle! The engine seems to have lost power. What are some of the scenarios from overheating (valves sticking, bent valves, fouled plugs, etc). NOTE: Vehicle has been used (1.5 years) for towing a 28' enclosed trailer with extra height(9000-10000lbs). Is vehicle just wore out?????
Mearntain
06-30-2019 09:46 AM
Hometown Pride
01-22-2007 09:28 PM
1985ColumbusF150
10-04-2004 12:09 PM
